โAug-07-2019 10:23 AM
โAug-08-2019 12:02 PM
wnjj wrote:That's exactly how I installed mine. That way, if I forget to turn the battery switch on while I'm towing, my breakaway system will still work.bob213 wrote:
Check to make sure that it disconnects everything from the battery. Some leave the CO detector and radio preset connected. These will deplete your battery in a short time.
Almost everything. You should leave the trailer brake breakaway switch wired direct to the battery so they will still do their job even with the switch off (like when towing it from storage).
โAug-08-2019 08:45 AM
โAug-08-2019 06:35 AM
afidel wrote:Abrahamseven38 wrote:
Are the easy. To install? I like easy.
Yeah, pretty easy, the biggest trouble with mine was researching to find what size ring terminal was needed and then actually finding them at Home Depot. After that it was: disconnect battery, cut the wire, strip wire, install ring terminals, mount switch, reconnect battery. It couldn't be much easier. I got This style.
โAug-08-2019 06:21 AM
โAug-08-2019 06:00 AM
โAug-07-2019 06:54 PM
โAug-07-2019 10:30 AM
