RamblinRalph:
I had a similar situation occur with my intellitec switch. I replaced the switch first because the rocker was sticking. No luck! Had to replace the relay too. Three years ,no problems. You could check the connections on your relay first. They might be loose.
Bob
2011 Ford F-350 PSD SC DRW
2008 Bigfoot 25C-10.4E
Firestone airbags - torklift stable-loads,fastguns,Talons Rancho rs 9000XLโs
