wowens79's avatar
wowens79
Sep 25, 2016
Battery Disconnect ???
I want to add a disco switch so I don't have to undo the battery boxes, and disconnect the Cables all the time.
My set up is typical 2 batteries, wired in parallel. My only thing that is different is I have a residential fridge with an inverter. The way it is connected is the inverter had its own cables going directly to the battery, and I also have the normal cables going to the battery.
I'm assuming I can just connect the inverter cable and the normal cables to the switch.
Am I missing anything with this line of thinking??
