Sep-17-2021 05:51 PM
Sep-30-2021 07:01 AM
FWC wrote:
Again, this is all a distraction from the point I was actually making.
The point in the very unlikely circumstance that you need to use your LiFePO4 camper battery in temperatures below -20C, the battery will work just fine, you will be able to fire up the furnace or battery heater and warm up the camper. At that point you can charge your battery, fill your water tank, and do what every you need to do.
Every time there is a discussion of LiFePO4 batteries, there are always a few who say that they are no good if you camp in cold weather (some are now even claiming 'cool weather'). My experience is exactly the opposite, they have worked just fine for me in cold weather. Yes there are limitations on charging, but these are generally easy to overcome, and are not nearly as restrictive as the limitations on your water system.
Sep-30-2021 04:59 AM
Sep-29-2021 01:30 PM
Sep-29-2021 08:37 AM
Sep-29-2021 07:26 AM
StirCrazy wrote:
interesting, at -30 they have more capacity available than SIO2 (80% Vs 60%) first time I have seen a chart that shows preformance below -20.
is there a corasponding chart that shows if there is a impact on cycle life when used at these temps or if the amprage (flow) is impared?
Nevermind, I just saw that was at a 9 amp discharge. more than enough to run a furnace.......
Steve
Sep-29-2021 07:16 AM
Grit dog wrote:
^Ok, fair enough. So you are a researcher in Anarctica. (Because the Arctic never gets that cold and by never I mean at least since LiFePO4 batteries have been around)
And apparently you’re out with your instruments on the coldest days of the year or decade in Antarctica. They’re not going to work bud.
I’d like to hear how you operate in -94F temps and colder….I’m just a greenhorn I suppose because much below -50F, nothing runs. At -60 you virtually can’t keep heaters fired to to keep fuel heated enough to fire the heaters to have a place to warm your batteries.
Even in the Arctic you don’t really go outside much below -50F.
Not everyone here has worked or lived above the Arctic circle so your claims may sound impressive but until you can explain the process I’m not buying it.
Oh, you must be a freelancer, because I don’t know of any agency or r company that operates in the Arctic that doesn’t have strict cold weather protocols that shut down virtually everything between -35 and -50F for safety.
But maybe that’s changed since I worked on the Slope in the winter.
Sep-29-2021 06:43 AM
FWC wrote:
There is no physical reason that LiFePO4 batteries can't be discharged below -20C. I don't pre-warm them in any way, just use them. They are generally rated for -20, because they only test to -20C because 99.9% of their customers don't care about performance below -20C. However, some manufacturers do test down to lower temperatures and while they loose capacity at low temperatures, it is not nearly as bad as many battery chemistries:
Sep-28-2021 02:37 PM
Sep-28-2021 01:48 PM
Sep-28-2021 07:57 AM
Sep-28-2021 06:56 AM
Sep-28-2021 06:38 AM
FWC wrote:Grit dog wrote:
Or more accurately, even though "you" personally want your rig "camp-able" at -30 deg and colder, LiFe's still have issues below freezing and you can't just "turn on he furnace" as one person suggested, although they will still "work" to discharge, IE provide power down to well below freezing (Not -30, someone can look it up though ). It's charging when the batteries themselves are around or below freezing.
Bottom line, they are a great option for lightweight, and duty cycle for warm weather campers. Not worth fiddling with if one is winter camping.
Although it appears some folks (on rvnet here anyway) really enjoy engineering and maintaining "off grid" solutions. I wonder if the "maintenance free" aspect of LiFe's is lost on the added $ and effort to make them work though.
Why would you not be able to turn on the furnace at -30?
PS, I winter camp extensively with my LiFePO4 batteries and have used LiFePO4 batteries well below -30 (just not in my camper).
Sep-27-2021 10:01 PM
Sep-27-2021 06:30 PM
Sep-27-2021 04:30 PM
