โJul-14-2020 10:26 PM
CB
Channel 17Redneck Express
โJul-20-2020 12:58 PM
CaFordGuy wrote:
For the cleanest install with perhaps the shortest wire runs, look at the Blue Sea Systems remote control switches if you have two banks use two switches.
Geewizard wrote:bigorange wrote:RoyB wrote:
I have had good luck with the BLUE SEA Rotary Battery Switches. These are sealed to prevent internal arcing... Like the idea of the using good same length cables with ring terminals connection
Blue Sea switches and cables purchased from AMAZON...
Roy Ken
Agree. Very pleased with Blue Sea and they surface mount nicely.
+1
CB
โJul-19-2020 06:45 AM
Roy Ken
โJul-18-2020 09:55 PM
โJul-16-2020 06:05 PM
bighatnohorse wrote:
A bit spendy:
https://www.hodgesmarine.com/blu1482-blue-sea-1482-120v-ac-rotary-30a-off--3-sources.html?gclid=Cj0K...https://www.hodgesmarine.com/blu1482-blue-sea-1482-120v-ac-rotary-30a-off--3-sources.html?gclid=Cj0KCQjw9b_4BRCMARIsADMUIypF1sv9oBcDW8n53E4aEDZbJlCIbaIE3jzeCSL06uBpPuh9uXZ2M-caAmAqEALw_wcB
CB
โJul-16-2020 05:48 PM
โJul-16-2020 05:03 PM
CB
โJul-16-2020 02:19 PM
AnEv942 wrote:
Most any of the battery switches that have protruding dial section would be easily flush mounted. Require making mounting ring attached to back side of wall, screwing switch to it from back side. Or if you don't mind screws showing just a spacer on back side (if panel not thick enough) between switch and wall and screw/nut thru all, like many marine applications.
I have the round Perko style, no ears, so would end up a bit recessed on 1/8" panel. Doesn't really lend itself to flush mounting. To flush mount it Id separate dial face label and knob, mount with shaft thru panel, stick label on panel reattach knob. Have to get creative on mounting spacer for no visible screws.
Is there a thread showing what coveredwagon did?
CB
โJul-16-2020 10:36 AM
Roy Ken
โJul-16-2020 09:42 AM
JoeChiOhki wrote:
These seem to be primarily about charging isolation vs battery selection for usage.
On the KIT, I just wired both batteries together in parallel and hooked the +/- leads to opposite ends of the battery bundle to even their usage out, but I noticed even with that, the lead battery still took more wear than the trailing battery (I have two in the main house bank).
The new rig, I'm setting it up so that the batteries are only conjoined when the selector makes them so, allowing for me to cut between battery 1, battery 2 or both batteries at the same time for powering the camper when off shore power.
I could make use of one of these eatons though for controlling the charging process to the batteries coming from the trucks charge plug and 3-stage converter.
โJul-16-2020 09:18 AM
โJul-15-2020 06:20 PM
Kayteg1 wrote:
I wonder why switch in the first place?
Battery separators like EATON are pretty affordable, come in 1-way or 2-way design, have connection for optional control light and emergency switch.
They make "set it and forget it" operation.
With switches there is margin for senior moment, even with young campers.
CB
โJul-15-2020 06:20 AM
โJul-15-2020 05:35 AM
โJul-15-2020 04:32 AM
