Spade_Cooley's avatar
Spade_Cooley
Best Carbon Mononide Detector?
The unit I installed in my trailer a year ago gave up and I need a new one. Which brand do you like? I like the battery type.
  • What is needed is a dual chamber detector that will detect CO and smoke from a slow smoldering fire such as may start in a R/V because of electrical fires and fast burning smokeless fires.
    After a lot of research and talking to Kidde, they assured me that this one would work in a home and also A RV,there is no difference.
    This is what I found.
    A Kidde KN-COSM-XTR-B Nighthawk
    That seemed to be best suited for this kind of application.
    Like This
    They now can be bought at Home Depot, also At Amazon.
    Amazon
    I suggest you read all the info and make your decision on this but I replaced the ones in my Class C with this one.They are rated for 7 years
    and most are only rated for 5,If your RV is older than 5 years old and they haven't been changed they are most likely no good. Mine needed to be replaced so this was a good deal for me.
    Just a reminder,a first line of defense is always the best. Check those smoke detectors and replace them if needed,all have a date on them and how long they are good for. If they don't, toss them.
    I hope that this helps,
