- CaLBaRExplorer
LarryJM wrote:
tshirtman wrote:
What brand do most RV owners use to caulk the seals on the exterior of their rigs?
I'm a rogue and partial to the more robust 3M brand Marine adhesives/sealants especially the UV4000. I redid my entire trailer where it still required caulking with the 3M UV4000 almost 8 years ago and it still looks as good and pristine as when I originally applied it.
Larry
I agree with Larry. I have had a trouble spot on the front of my trailer for years where it constantly split over temperature changes not matter what I used. Just re-caulked with 3M UV4000 and no splitting yet after 4 months and going from 70F to 5F here in Canada. Proflex would split after going from 70F to 55F. More money but so far seems far superior.
Rob - Mortimer_BrewstExplorer IIIf you are looking for caulk, I obviously Dicor is the way to go. You will get better results if you keep a bowl of soapy water at hand. Dip your finger and smooth the joint.
Use Eternabond tape for repairs. - LarryJMExplorer II
Larry - RVcircusExplorer II+1...these are my preferred sealants.
Old-Biscuit wrote:
Dicor Self-Leveling for roof
X eleventy-billion- KeithRExplorerDicor
- path1Explorer
In my opinion, the most used brand of caulking is Dicor.
What type of Dicor for your application is another question. - DutchmenSportExplorerNo disputing: Dicor.
- bobndotExplorer II
x2.
I use it in 'brite white' . I found 'white' yellows. - BumpyroadExplorerwhatever the mfr. suggests. current TT is urethane based.
bumpy
About Travel Trailer Group
44,029 PostsLatest Activity: Jan 21, 2025
