All things will vibrate from some sort of input. When the input harmonic matches the thing’s natural harmonic and if the input continues to input, the thing will vibrate more within the same frequency.
Your running over the expansion joints sets up an input to your truck. Your speed dictates the frequency of the input to your TV.
Slowing down and/or speeding up will change the input frequency to your truck.
As for you trucks harmonic...the things that are part or contribute to its harmonic are the tires, suspension (shocks, bushing, shocks, architecture, etc), the body bushings to frame and a big ETC.
The Kelderman suspension you mention changes the suspension architecture and the air bags adjust what the input’s amplitude & suspension response...AKA tunes the suspension harmonic
Other than changing your speed, changing the tire PSI changes its harmonics, change the shocks and can go either way...more or less dampening, and everything else in that food chain.
Easiest and lowest cost is changing your speed...
