Jul-25-2017 05:47 PM
Sep-09-2017 07:16 AM
Sep-08-2017 06:30 PM
Sep-08-2017 06:06 PM
Jul-27-2017 04:15 AM
Jul-26-2017 12:23 PM
Jul-26-2017 10:48 AM
Jul-26-2017 10:40 AM
2001400ex wrote:
One other thing that's not mentioned. You could check the weighting of your load. For instance, you might need more weight on the front of your trailer to reduce sway. That being said, my comfortability, go with a bigger pickup. I'd rather have a bunch of excess capacity when it comes to towing.
Jul-26-2017 10:39 AM
Grit dog wrote:
Well your on the fast track to a towing dream. If you're not down with your current rig (it's pretty maxed out where you're at now) just go upgrade now and be done with it!
Any of the big 3 HD pickups will do awesome. We all have our favorites and personally I could flip a coin between the 2 you've mentioned. Be prepared to be lulled asleep towing your trailer with a big truck compared to your current rig!
Jul-26-2017 10:35 AM
MitchF150 wrote:
Keith, that's the route I would take too... That Tundra is a nice truck, but just not up to the task at hand IMO.. Especially if you intend to go to a 5ver..
A 3500 will give you more capacity and room to grow if that's the future plans. But, a 2500 will work within it's limits too..
Good luck!
Mitch
Jul-26-2017 10:31 AM
Trackrig wrote:
You do need a bigger truck, but before you grab any old 3/4 ton truck, go look at 5th whl trailers also or you could wind up with a truck not suitable for the 5th wheel trl and then be buying your third truck.
Bill
Jul-26-2017 09:52 AM
Jul-26-2017 08:30 AM
Jul-26-2017 08:23 AM
Rover_Bill wrote:
Before you put down any money on a bigger TV, remember that a strong enough crosswind will flip even a big heavy semi. If it was my rig, I would get the true tongue weight and steering axle weight from a commercial truck scale and setup the WD correctly.
My TV/TT rig is very similar to yours - 3.6L V6, 30' TT, 7,000# tow, 12,000# gross. It is setup with a near perfect weight distribution. Last year I did a 4,000 mile trip through New England and had absolutely NO sway issues including going downgrade in the mountains at 70 MPH with a gusting 30 MPH crosswind while passing semis.
Jul-26-2017 06:24 AM
