mr__ed's avatar
mr__ed
Biodiesel
A few days ago I was towing my fiver through OK on the way to AR when I stopped at a Loves Travel Plaza to fuel up. I started refueling and then noticed a tag on the pump stating 15 percent biodiesel. Being suspicious I stopped the fueling at about 6 gallons and got out my owner's manual. It stated that I should use no more than 5 percent biodiesel. So I left Loves and went to another station further down the road where the pump didn't state biodeisel and filled the tank.
Well, a little further on the check engine light (CEL) came on but the truck still ran fine. I read the code and it said something about the particulate filter, pressure sensor circuit high. Since there were no obvious drivability issues I continued on to my destination and the next day the CEL eventually went out.
So I'm wondering if that 6 gallons of 15 percent biodiesel may have caused the CEL. It was quite diluted by the time I filled up so the CEL could have been a coincidence.
What about you other later model diesel owners? Do you steer clear of biodiesel or use it with no apparent problems?
  • You must also consider that some places don't tag the pumps and are still selling a biodiesel blend.
    Minnesota for one. Says nothing most pumps, yet you are still getting biodiesel.
    As said earlier, probably kicked up some gunk. Biodiesel good for that when first used. Change the fuel filter and drive happily along.
  • Executive wrote:
    Cummins certifies my engine is ok to run on the B20 fuel. Here's a link you might find interesting.....Dennis
    Biodeisel FAQ
    Thanks for the link, Executive. I did find the info a little vague pertaining to my specific vehicle (2007 Dodge RAM 3500 w/Cummins 6.7L engine). I copied some info from that link below:
    Chrysler supports B20 use in the Dodge Ram for approved Government, Military and Commercial Fleets; B5 approved for all other diesel vehicle applications.
    I see gov't, military and commercial mentioned but not a standard-use pickup. Perhaps I'm missing something here....
  • My 09 6.4 is only approved for 5% bio makes it difficult to find #2 in the mid-west states they all seem to have the up to 20% bio sticker. I did have to run it just to get out of there and had no problems....yet.
  • The biodiesel might have loosened up some goop in the fuel tank and lines and was trapped in the filter. Likely hurt nothing, but since it triggered the light, might not be a bad idea to replace the fuel filter. Cheap hedge against any possible problem...........
