wmoses wrote:
JJBIRISH wrote:
The absolute best cleaner for the black tank bar none is some powered dishwasher detergent Cascade Complete all in one, with water…. Let it soak and then then drive around before dumping…
Interesting. No Calgon needed too? How much should I put in my 37 gallon tank?
First of all I do not see the need for cleaning the black tank if enough water is used, except maybe for the end of season cleaning… where I would use between one or two cups (more than enough) dissolved in four or five gallons of water then driving around a little…
Dishwashing detergent is a heavily concentrated low sudsing detergent with a blend of water conditioners, soil suspending agents, wetting agents and the necessary alkalinity to tackle tough greasy soils… older versions of dishwasher detergent were better because they were both enzyme and phosphate based, but they are no longer available… might just as well use it on the gray tanks while you are at it…
If the OP has a build up as he claims it might need done a couple of times…
If there is really a build-up it would be best to camera the inside of the tank to see the actual problem first… instead of wasting time doing things that might not help… inspection cameras are getting cheaper all the time… you will find dozens of uses for it around the shop car and RV, any hard to see places…
http://www.harborfreight.com/digital-inspection-camera-67979.html
