camperforlife
Jul 04, 2013Explorer
When you cut the underbelly cut a three sided flap especially if it is coroplast. When closing up the belly, you can punch a couple holes at the loose end of the coroplast and secure it shut with zip ties before you seal the seams with Gorilla tape.
Get the shortest cable as possible to suit your needs. If the cable is too long make a wide arc so it won't kink and anchor it in twice as many places as you think is needed. You will see that the manufacturer just hooked up the cable, kind of anchored it and closed things up.
Good luck!
Good luck!
