valhalla360
Aug 28, 2022Navigator
Lantley wrote:dieseltruckdriver wrote:
I wanted to add one more thing that hasn't been posted. Everything in your black tank is something you ate or drank. There's nothing else in there, unless you add a small amount of chemicals. The grey tank is water and soap. The same that you just washed your hands with.
The best part of owning an rv over tenting is having your own private facilities with you. Once you start using it, you will wonder why you waited so long.
Just because it went in your mouth does not mean its germ or bacteria free when it comes out the other end! I'm not sure what your point is!
The grey tank also contains grease , skin folicles and stagnant water.
Waste water water is not germ free. Otherwise we would not need traps to seal off sewer piping.
The point is...if your fecal matter has a nasty disease present, as the only users of that facility, you have already been exposed to it. This does assume you don't let a lot of random people into your RV to use the facilities.
Traps are not to prevent germs from getting into your living space...they won't (household or RV). They are to stop sewage odors and methane from entering the living space. There are roof vents to allow them to escape.
