โMar-14-2014 03:54 AM
โApr-27-2014 08:36 AM
โApr-27-2014 08:24 AM
โApr-27-2014 07:55 AM
Me Again wrote:
There is only one remaining higher end controller with MaxBrake out of production. It is http://www.brakecontroller.com/direclink.htm.
If you can find a used MaxBrake and work with Dutch and Di to get the brake line fitting for your vehicle, you will have the best controller available in recent years.
Hundreds of thousand's of people tow with Prodigy's and think they are fine. I never liked mine, having to play with Boost settings, and city vs highway was always a compromise.
With the MaxBrake the truck and trailer always just stop like a single unit, as it measures brake fluid pressure with a load cell in the brake line.
Controllers like the Prodigy require the tow vehicle to slow down first. So they add boost settings that start applying part of the braking current to the trailer to minute you touch the brake pedal.
So I would set this for highway use and in the city we would get the trailer jerking on the truck. Turn down Boost for city drive and forget to turn it back up for highway driving and you can come up short when you really need your brakes.
Chris
โApr-26-2014 01:33 PM
โApr-26-2014 01:13 PM
hone eagle wrote:
direclink
Now that Maxbrake is gone here is a controller for those who want better then 'good enough'
there is video on U tube where a mag tested it and it shortened a emergency stop by 80 feet.
anti lock to the trailer and seamless like a hayes or max brake.
โApr-26-2014 12:52 PM
โApr-26-2014 11:47 AM
โApr-26-2014 07:28 AM
โMar-14-2014 08:55 PM
โMar-14-2014 04:39 PM
hone eagle wrote:bikendan wrote:rob37dawn wrote:
I searched brake controller in the forms and did not come up with much.
How can you not come up with much, when the Prodigy brake controllers are recommended overwhelmingly in these Forums, all the time?:h
These forums are not the centre of the RV universe.
Unless you have used both you can't say the prodigy is the best .....I have and its not.
โMar-14-2014 03:33 PM
โMar-14-2014 01:32 PM
โMar-14-2014 01:27 PM
โMar-14-2014 12:30 PM
