Our 93 Terry Resort XT1 16h had a old break away switch that didn't look to be in the best shape so we purchased a new Tekonsha break away switch. I understand that one wire goes to blue brake wire the other goes straight to TT battery. My question is: Is there any way to test the new switch short of using a multi-meter on brakes them self? I pull the pin but hear no humming from brakes. The trailer brakes do work while hooked up to TV. Im sorry if this is a newb question. Thanks for any help.
You can do a quick check on the brake magnets on the trailer with an inexpensive hunting compass. With the power applied it should point right at the magnet when placed near the rim.
Jerry9n 2009 23' Cikira Escape EXP 2006 Ford Expedition Reese Pro Series SC Tekonsha Primus IQ HTT Mods
Battery is fully charged. I was thinking I should hear a humming. Also didnt know that I could burn up my brake controller if it was hook up when the break away switch came out. Thanks again.
The brakes should only hum when actuated by the controller. This because the controller pulses the power to the brakes. When you pull the breakaway switch, it applies a full 12V and it won't hum.
is you battery good? What Terryallan say is a easier way to check. also you could jack up on side of the trailer and spin the wheels to see if they stop when the pin pulled
2003 dodge 2wheel drive diesel 375hp 750torque 2007 citation fifth wheel model 29bhs to see pictures of my truck and fifth-wheel click on view profile
Yep. Hookup to the TV. DO NOT hook up the 7 pin. pull the breakaway pin out, and try to move the TT. IF it moves. It's not working, IF the brakes are locked. It's working.
Terry & Shay Coachman Apex 288BH. 2013 F150 XLT Off Road 5.0, 3.73 Lazy Campers
