Aug-11-2020 04:26 PM
Aug-16-2020 09:21 AM
dodge guy wrote:
The brake magnets will in fact weaken if left on for longer than what is recommended. they will not cook. but they will weaken if left on for lets say a few hours.
Aug-15-2020 04:44 PM
Aug-15-2020 04:23 PM
AJR wrote:
Holy cow! As I remember it the breakaway switch was a simple device that applied battery power to the TT brakes when the plug was pulled. I also remember there was a concern if you pulled the plug by accident the trailer brake coils could cook.
Aug-15-2020 03:42 PM
Aug-15-2020 02:33 PM
opnspaces wrote:Gdetrailer wrote:
Heck even on my TT, I have added a relay so when the pin is pulled it automatically disconnects the brake wiring electrically from the vehicle. The vehicle brake controller will now give you a warning of no connection before you start driving..
Gdetrailer, maybe I just haven't had enough caffeine, but having trouble picturing the wiring of your relay.
I can see a normally closed relay where the the brake signal wire runs through from the tow vehicle. But what are you using for the power and ground on the trigger wire?
Aug-15-2020 09:19 AM
Aug-15-2020 09:10 AM
Aug-13-2020 08:09 PM
Edd505 wrote:
it's simple to test, pull the pin and see if you can pull the RV. I have had the pin pulled accidentally making 75%? corner, locked the brakes mid turn. The RV brakes are power by the battery, dead battery = no brakes.
Aug-13-2020 05:33 PM
Aug-13-2020 05:22 PM
Aug-13-2020 06:29 AM
Kelpike wrote:
Hi, im not sure how to reduce the width of my picture. Thank you for clarifying my wiring connections.
Edd505 wrote:
what came off it, 2 wire or 3? Most are two wire and makes no differance on which goes where it's an on off switch. Pin in it's off pin out it puts 12V to the trailer brakes.
Aug-12-2020 07:44 PM
Kelpike wrote:
Sorry Gdetrailer, I was creating my last post when you posted yours. Thank you for your reply.
Aug-12-2020 07:43 PM
Aug-12-2020 07:38 PM
dodge guy wrote:
That's good to know GD. But seems to be complicating the system! No reason to have an LED when you can see if the plunger is out.
