....I don't use wood between the camper/bulkhead/rubber bumpers. I have large 4x4 inch x 4 foot wide blocks of closed-cell high density foam (from industrial air conditioner packaging)...the "foam" cell material is actually polyethylene (not polystyrene). The blocks go just about right across the front bulkhead and have slots around the 2 camper rubber bumpers. The foam supports the camper all the way across spreading the load on camper tub so that the rubber bumpers will only engage in extreme conditions (like driving down our driveway's nearly vertical slope, or similar extreme truck camper terrain LOL). The stand-off spacing between my rubber bumpers and the truck bulkhead is about 0.5 ~0.7 inches. Our driveway is so steep, that when backing Sabconsulting (Steve)'s rental Class C down our driveway (at the top of the driveway; Steve managed to drive it all the way to the top LOL!), the front wheels of the Class C came off the ground and were only grazing the gravel....I was able to regain load balance (by divine intervention and tap braking), and managed to front-wheel drag the camper to a stop, before continuing down the remaining 340 feet of driveway.
I also have these same foam blocks fore of both wheel-wells to keep camper from pivoting between the wheel wells (I have about ~1 inch between camper tub and wheel-wells at each side).
SidecarFlip wrote:
One thing to keep in mind when shortening the bump stops is, the rear clearance between the bed pillars and the back of the camper (if you have a back wrap.
...excellent point.
