Oct-10-2017 04:10 PM
Oct-17-2017 06:06 AM
Oct-12-2017 08:47 AM
rrupert wrote:
In the installation drawings it appears that the electrical receptacle is mounted just to the left of the receiver and it's tilted down at maybe a 45 degree angle. Maybe the mounting bracket for it is not OEM.
Oct-12-2017 06:14 AM
Amateur Radio K3EXU
Oct-11-2017 01:17 PM
mike-s wrote:
Assuming that's really an OEM hitch, the installation instructions are here (hitch found here), and it replaces the bumper (the actual steel bumper, not the cover). The mounting holes in the bumper cover and the hitch should line up, they don't in your picture.
The collision may have bent the hitch, which is also the bumper. Or maybe the bumper cover just needs to be notched. Part of the installation is also notching out the bumper cover (see steps 21 and 22). It looks like that wasn't done for the replacement. Maybe that's all that's keeping things from lining up and allowing access to the connector.
Oct-11-2017 11:41 AM
Oct-11-2017 10:21 AM
Oct-11-2017 07:12 AM
Oct-11-2017 07:00 AM
Oct-11-2017 06:29 AM
rrupert wrote:
I assume your hitch is integral to the bumper if it is an OEM hitch. The after market hitches usually mount below the bumper. Assuming yours is OEM, I would make sure everything in mounted there properly. Maybe a trip to your dealership to
have them check it would be in order. If they think it isn't right take it back to the body shop. My concern would be that it isn't mounted properly both the bumper and hitch are in jeopardy of failure.
Oct-11-2017 05:50 AM
Amateur Radio K3EXU
Oct-10-2017 08:29 PM
Oct-10-2017 08:05 PM
Oct-10-2017 07:01 PM
Oct-10-2017 05:47 PM
