Burning smell from new trailer furnace
RV_Bound
We just turned our furnace on for the first time in our new Puma 23FB and the trailer smells like smoke and the smoke detector even went off. It even seems smokey in the trailer. It seems like more than just burning off the newness. What could it be? The CO2 detector did not go off.
Andria
16 REPLIES 16
Farm_Camp
mileshuff wrote:
We have a new trailer as well and have not used the furnace yet. On our next trip we'll probably need it at night. Should we open the windows and turn it on low while we go out for a few hours? I sure don't want to breathe that smoke while there!
Not sure I'd leave it unattended for hours with the windows open but the general idea is that you will needs lots of venting while it breaks in.
We had the same thing - horrible smell and it set off the smoke detector. I have an autistic kid that does not react well to sudden very loud sounds... So... We ended up sleeping overnight without the heat that night for the sake of domestic tranquility. LOL.. It got down into the lower 40s(F) but we all had sleeping bags and it worked out.
The next morning I pulled the battery out of the smoke detector while I ran it through a few on/off cycles over a couple of hours or so with the doors and a vent open. The next night the smell was almost 100% gone and no more alarms. Thank goodness... Next year I'll know to give it a break in run or two in advance!
If you can just go fire it up now before your trip for a hour or two (let it cycle on and off several times and vent it.) Then you'll have no issue when you get out camping.
TV: 2010 F250 XLT 4X4 SC SB 5.4L 3.73 - "The Blue Monster" (2013-2018) Traded at 100K
TV: 2017 F250 XLT 4X4 CC SB 6.7L PD 3.31 - "The Silver Streak"
TT: 2014 Starcraft Autumn Ridge 329BHU
Our Story...
Places we've camped
dodge_guy
Our TT`s (we`ve bought 2 brand new) had the burning smell too. they will need to run for a few hours to burn off the Manufacturing oils. and even after that it will still smell a little bit! I would recommend running it before a trip. better to burn it off in the driveway rather than in the middle of a trip!
Wife Kim
Son Brandon 17yrs
Daughter Marissa 16yrs
Dog Bailey
A bad day camping is
mileshuff
2014 Winnebago 26FWRKS 5th Wheel
2007.5 Dodge 2500 6.7L Diesel
2004 Dodge Durango Hemi 3.55 (Used to tow TT)
mkirsch
Nomad II
Nomad II
Vegetable oils themselves might not be toxic, but the SMOKE from vegetable oil is as toxic as smoke from a wood fire.
It's not the "one whiff and you're dead" toxic. More like mildly toxic, like if you breathe it for decades you'll end up with lung cancer toxic.
Obviously you won't be breathing the smoke for decades, so it's nothing to worry about.
spadoctor
The oil should have been burned off already if the dealer had done a complete and proper prep. That being said, a neighbor found nuts and acorns on the heat exchanger causing a smell. Turns out mice can enter the trailer thru the duct that is openended in the basement for ank heat.
Lynnmor
Had a burning smell from a furnace in a new trailer once. Turned out that the idiots left the paperwork on top of the furnace. I told a fellow camper that had the same model as mine and he found the same thing.
sbowman871
Yep, CO2 wouldn't have gone off.
2010 Everlite 29FK
2011 Ford F150 V6 Ecoboost Max Tow 3.73
Parkit 360
Reddog1
Moved from TC Forum.
Wayne
Moderator
2004.5 Ram SLT LB 3500 DRW Quad Cab 4x4
1988 Bigfoot (C11.5) TC (1900# w/standard equip. per decal), 130 watts solar, 100 AH AGM, Polar Cub A/C, EU2000i Honda
Toad: 91 Zuke
Buzzcut1
Nomad II
Nomad II
I thought this was the truck camper forum?
Although I do realize that we are a most resourceful group.
2011 F350 6.7L Diesel 4x4 CrewCab longbed Dually, 2019 Lance 1062, Torqlift Talons, Fast Guns, upper and lower Stable Loads, Super Hitch, 48" Super Truss, Airlift loadlifter 5000 extreme airbags
ScottG
FWIW, it's just vegetable oil so it's non-toxic.
DutchmenSport
Ah, I remember that from our first TT and second TT! Our first was a total shock! It smelled so bad we couldn't stay in the camper. It took about an hour to burn off the oils. We called the RV dealer the next day and he explained it to us.. perfectly natural ... it will get better! Let it run, open the windows, air it out. In a couple hours and once the camper airs out, you'll be fine!
Our last TT (our Outback), the dealer completely prepped it. When we fired up the furnace the firs time, there were no smells. They'd already done that between the time we signed and 3 days later when we picked it up. Sweet.
Perfectly natural ... just let it run a little and pull the batteries from all the detectors so they'll shut-up!
sclark
The heat exchanger is coated with oil in order to prevent oxidation. The smell is normal until the oil is burned off of the surface. Good luck with your new rig.
2013 Ram 3500 Crew Cab Cummins Aisin transmission
2014 KZ 358BHK
Honda eu3000is Generator
kohldad
Should be normal. Even on older units, it is not uncommon to get a slight burn smell the first burn of a season. This is from the dust build up.
However, to be safe, look at the areas you can to make sure nothing was left laying up against the combustion chamber. If there is a drawer above it, lots of time you can pull it out to look down into the area.
2015 Ram 3500 4x4 Crew Cab SRW 6.4 Hemi LB 3.73 (12.4 hand calc avg mpg after 92,000 miles with camper)
2004 Lance 815 (prev: 2004 FW 35'; 1994 TT 30'; Tents)
SCVJeff
RV Bound wrote:
---snip-- The CO2 detector did not go off.
That's a good thing. Otherwise you would have a problem!
Jeff - WA6EQU
'06 Itasca Meridian 34H, CAT C7/350
