โJul-06-2014 04:05 PM
โJul-09-2014 10:42 AM
โJul-09-2014 10:04 AM
walker111 wrote:ib516 wrote:NY RVer wrote:
I agree on making sure everything is ok before heading out. I just came back from dropping off my '06 F350 at the night drop off because I am concerned about my next trip. Last time out, temp rose above normal every time I went up a hill, and coolant came out of the degas bottle. Left it at one dealer for a week, and they couldn't find the problem. I'm thinking head gaskets, hopefully not, but we shall see. Planned on heading out next weekend, so hope all goes well. Good luck with your truck.
That sounds like a classic sign your 6.0L is about to cost you a whole lot of money. The egr cooler coolant passages become restricted and/or clog, the coolant flash boils due to reduced flow which lacks the ability to absorb the amount of heat it needs to, and the first sign is that the degas bottle pukes coolant. The oil cooler is likely on it's way out too.
Do some reading here
This is not a 6.0 l
2012 6.7
โJul-09-2014 09:18 AM
โJul-09-2014 12:07 AM
โJul-08-2014 07:19 PM
โJul-08-2014 06:50 PM
โJul-08-2014 05:43 PM
โJul-08-2014 10:07 AM
โJul-08-2014 05:44 AM
walker111 wrote:
Update
Dealer did a manual regen to check for faults and found two problems.
Grounds needed to be cleaned up on wire connections somewhere and EGT sensor 14 fault and was replaced.
I agree that this was missed last week when in for light on.
Hope this is only issue.
Dame these newer diesels are so impressive in the torque ,towing, yet so picky!!!!
Looking forward to Saturday departure and burning some better quality fuel in the USA!!!!
Will drive some prior to make sure all is well. Dealer put 40 kilometers on the test drive.
Thanks again for replies.
โJul-08-2014 05:37 AM
โJul-08-2014 04:41 AM
โJul-07-2014 02:22 PM
โJul-07-2014 09:06 AM
Ric Flair wrote:FishOnOne wrote:45Ricochet wrote:
CEL's are normal according to Ricatic on the 2011 models. Just search his user name for more information. I'd just keep up with your plans, what could possibility go wrong :W
Exactly... And the Dodge boys are almost exclusive to CEL's with '13-'14 Cummins power trucks. Some don't even make it from the dealer lot to their drive way without a CEL. :W
Is that the warning light that tells them to get to a GM dealer immediately and trade it in for a good truck?
โJul-07-2014 08:48 AM
