Lan.N wrote:
Wow, I wasn't expecting so many replies. Thank you everyone for your help. Unfortunately, the exact payload number is not available right now. It's a long story, but basically the dealership messed up and gave us a truck without the max towing package. The replacement truck will be here next week with a GVWR rating of 7600 lbs. The current truck has a rating of 7200 GVWR; the payload sticker on the door right now is 1638 lbs. The replacement vehicle will probably not see a 400 lbs increase since it will be heavier equipped, so I'm guessing the new payload rating will be 1800 - 1900 lbs.
The TT being discussed has a 715 lbs hitch weight. According to Krobbe formula:
Payload Limit: 1800
Passenger: 400 (2 small people and 2 huge dogs)
Cargo: 200
WDH: 100
1800-400-200-100 =1100
1100/.15 = 7333 lbs (lol, the same number as you)
Looking at the result I should not exceed 7333 lbs in towing?
Some of you were wondering why I got a 1/2 ton instead of something bigger. First of all, I stated that we were inching closer to our dreams, meaning that we are taking steps toward it... Obviously, without any monetary constraints, we will get the biggest and baddest tow vehicle to tow whatever we want (or probably just get a class A.); life however is more complicated. We are both young adults and still have student loans to pay off. We still have to work in crowded cities and getting a bulky expensive truck before going full time will not be practical at the moment. I'm sure in the future we will want to upgrade. Plus, we got the truck for a little over 37k, and getting something bigger right now would cost us much more $$$.
Once again, thank you everyone for the warm welcome and for all the advice. According to majority consensus I should go lighter and smaller. Some stated that I could probably tow it, but it will not be fun or safe in a 1/2 ton. Being inexperience, I wasn't sure and needed clarity. Thank you rv.net forum :) Since this TT is definitely vetoed. Will the Outback Terrain 250TRS be a better fit for my truck?
The TT specs:
Shipping Weight 5483
Carrying Capacity 2017
Hitch 585
Length 27' 6"
715lb dry hitch weight is probably right around 1000lbs fully loaded. Add in the rest and you are right up at the limits. A little flat land, short distance towing, you probably won't mind but if the goal is longer distance, longer term....
If the truck isn't here yet, talk to the dealer and see if they can switch you to a 3/4ton. Cost shouldn't be a much more and will give you more room to spare
