โJul-25-2016 09:30 AM
โJul-28-2016 03:12 AM
Lantley wrote:
RE Routing those vents and drain is generally not always a simple task.
However installing valves is an easy 5 minute job.
โJul-28-2016 03:07 AM
Lynnmor wrote:smkettner wrote:
Find out where the water is going and put a cork in it.
This is where the water comes from, and no, you don't cork vents that are there to keep the tank from swelling during filling.
The answer is to route the vents so they exit the coach well above the water level.
In this photo, the blue pipes at the top are the problem. When installed, the tank lays flat with the vents pointing down towards the road. It doesn't take a rocket scientist to understand that the water will spill out while rounding a curve or have the trailer on a tilt. As you can see, the tank will lose most of its water in a short period of time.
โJul-27-2016 06:25 PM
โJul-27-2016 05:53 PM
chracatoa wrote:
Every time I fill up my fresh water tank I lose half of the water on the way. So when I get to the campground I top it off.
My friend thought it was odd I had this problem until he ran out of water the next day. I think he lost water as well.
My guess is that the water spills out through the overflow hoses when we go up and down the hills.
Is this normal? Is there anything I could do here?
I wonder if the trailer is actually made to travel with the fresh water tank full.
โJul-27-2016 03:20 PM
โJul-27-2016 01:30 PM
โJul-27-2016 01:21 PM
โJul-26-2016 08:08 PM
Unless you are boon docking in the desert, there is little need to fill the fresh water tank more than a
a 1/3 full. A full tank of H20 adds significant weight to tow around.
โJul-26-2016 08:40 AM
โJul-26-2016 07:59 AM
โJul-25-2016 10:24 PM
โJul-25-2016 07:24 PM
โJul-25-2016 07:10 PM
โJul-25-2016 06:19 PM
darsben1 wrote:
Make the vent tube a big S that may stop it
โJul-25-2016 01:34 PM
