agesilaus
Aug 13, 2020Explorer III
Carelessness strikes again
We were driving around the wilds of Nebraska today, investigating the river that is 'a mile wide but only an inch deep'. We we heard disturbing sounds from the passenger side front wheel. Did not sound exactly like a bad brake pad tho but happened occasionally when the brake was applied. I thought maybe it was just starting to grind.
On this truck from the time you hear the first sound of grinding to a destroyed caliper is only a matter of a few hours so no delay can be considered.
Got back to the campsite and got out the brake pad gear and parts. Jacked up the truck, inspected the pads, not great but still at least 3/16th of an inch of pad showing. Hmmm...??
Get ready to pull the caliper off when I notice that the top bolt holding the caliper is gone, and the caliper has rotated maybe an inch!
Looks like I did not torque that bolt down enough, being of the packrat tribe I had saved a bolt from the the last time, in my bolt box, I replaced the calipers and got that installed and really torqued down...heh.
probably got distracted last time I worked on it.
