rb2boxer wrote:
subcamper wrote:
I removed the carpet in the bunk area on a Rockwood. The vinyl flooring did extend all the way under it.
The way they made the finished edge on the carpeting where it met the vinyl was to staple the rug upside-down and then fold it back over.
I did have to cut it at the wall edge as the interior wall was on top of the rug.
There are tiny staple holes but you won't notice them.
Steve
Do you have a slide in the bunkhouse? If so, were there any issues? In the living are there is a strip of carpet that runs along the floor against the slide carpet.....see that in all of them. I wasn't sure if having no carpet there would be an issue
Thanks for the info!!!
Yes, the carpet I removed was in front of a bunkhouse slide. There was no problem running the slide after removing the rug. The slide, however, doesn't have a piece of rug that slides over the main rug. It's just a wood front.
Our big dinette/couch slide has the strip of rug that is attached to the slide. There is carpeting in front of the slide. The rug strip attached to the slide moves over the top of the rug strip on the main floor. If that (rug strip on main floor)were to be removed, I don't think it would affect slide operation. The rug strip attached to the front of the slide would need to stay because it covers up the gap where the slide drops down into when fully open.
Steve
