Turtle n Peeps wrote:
Swamp Man wrote:
Been looking at the used MDT market and see a ton of trucks with CAT 3126, C-7, etc engines for sale. During my research it seems these engines allegedly have a lot of problems. I say allegedly as with any research on the net, you have to be careful. Any have one of these engines and how does/did it work out for you? I am aware that there are engines with failures that occur due to manufacturing defects in every brand. Some of the trucks listed have a good price but the old saying about if it sounds too good to be truth, it is.
All right, now that all the fan boys of the Cat can do no wrong have checked in, lets talk about some of the common problems with the C-7. :B
Before all the fan boys get all froggy on me let me first say that Cat makes some damn fine engines. Most of their stuff is anvil reliable and built like a brick,,,,,,,well you know. Unfortunately the C-7 isn't one of them.
Problem #1 is the HEUI. Back in time this was thought by Cat to be a good system. Years later Cat saw the error of their ways and dropped the whole oil pressure injector deal like a hot potato much like International did.
Problem #2 is injector cup leaks. My friend worked on diesels for over 35 yeas said they were a nightmare. He said the early ones with the copper cups were a bad deal. He said they came out with stainless steel later and that helped things a lot.
Problem #3 is the HEUI and injectors are very expensive and like I said above, have a bad habit of going out.
Problem #4 is when the HEUI goes out it is much like the CP4 pump. The HEUI have a bad habit of taking a dump and when they do it takes the WHOLE fuel system out with metal everywhere. Can you say, BIG BUCKS!
Here is a little reading about the C-7 common problems.
If you want the real story about the C-7 go to a Cat dealer and talk to a gray hair tech about common problems with this engine. Most will give you the true story.............both the good and the bad.
I thought the HEUI system on the CAT was the same system used on the 7.3 PSD. I know the 7.3 PSD HEUI fuel system can tolerate just about any diesel fuel contaminant known to man kind and keep on truckin.
I will say the the C-7 leaks oil like a sift. :E
