Apr-16-2019 05:44 PM
Apr-18-2019 10:57 AM
Apr-18-2019 09:26 AM
mkirsch wrote:
I'm sure Bigfoot isn't using off the shelf silicone from Home Depot.
Here's the deal: Household silicone is designed for use on houses that don't move. Dicor and similar products are designed for houses that DO move.
The translucent clear sealant is best to use for sealing cracks and gaps on many surfaces. You can use it for doors, windows, auto, gutters and bath, to name some. It is also waterproof that it can be applied outdoors or indoors.
The sealant does not also shrink or turn yellowish. You can also have peace of mind that it won’t stain the surface to which it is applied. It is also UV resistant that it can last long even with continuous exposure to the changing weathers and outdoor elements.
Aside from the mentioned applications, this product also works well in plumbing and gutters. You also don’t have to worry that it won’t adhere well because it is especially formulated for many types of surfaces. It can also be applied on a damp and slightly oily surface.
Another great thing that I love about this product is that it can be water ready in 30 minutes. That said you could also apply paint on top of it without any worries because it quickly sticks to the surface and dries.
The sealant is also waterproof, so you can look forward to a leak-free RV for a long time by choosing the Gorilla Silicone Sealant Caulk for your camper, automobile and recreational vehicle, and so on.
Apr-18-2019 08:37 AM
Apr-18-2019 08:00 AM
Apr-17-2019 03:42 PM
Apr-17-2019 03:21 PM
3 tons wrote:
Be careful with etarnabond, as a percaution I’d used it around the perimeter of the bath skylite thinking I’ll now never have a worry about a leak there ever - NOT So!!... A couple years later I noticed water leaking in around the skylite, but assumed the intrusion must have came from some other nearby area and not the skylite...Turned out that my assumption was very wrong and water being shed down from the skylite would hit the surrounding eternabond edge like a dam and then leak thru to the ceiling...A bead of caulking around the inside eternabond surround (where it meets the skylite) stopped the leak for good...
Apr-17-2019 02:44 PM
Apr-17-2019 09:30 AM
Apr-17-2019 08:53 AM
Apr-16-2019 08:38 PM
Apr-16-2019 07:11 PM
Apr-16-2019 06:58 PM
Apr-16-2019 06:52 PM
Apr-16-2019 06:50 PM
downtheroad wrote:
Stick with Dicor or Proflex.
I'm not a fan of silicone or anything exterior on any RV.
