Champion 3500 watt inverter
bowl2764
Since CW has dropped the price $300.00 thru June 19, considering a purchase. Does anyone here have any experience with this unit. Looks like it will be plenty of power for most of the RV needs, including 15000 ac unit.
18 REPLIES 18
JCR-1
What is the weight difference between the newer 3500 watt vs the orig. 3100 watt Champion inverter generator
Sandia_Man
We have the remote start 3100 watt version and it runs our rig's AC with ease even on Eco-mode at 7000' elevation. The 3500 watt version will have no problem running your AC unit. Our Champion inverter genny ran fine out of the box where we live at nearly 6K' elevation, but they recommend using a high elevation jet for use above 4K' which they immediately sent out after a quick call to their toll free service line. Their customer service is nothing short of awesome.
RooDude09
We have the 3100 model. Love it ran the 15k BTU AC most of the day last time we were out. Turned off the Eco throttle though. Not too noisy. The remote start is awesome. If I had to buy another I would get the 3500 model definitely.
pianotuna
Nomad II
Nomad II
Hi
I know the Yamaha 3000 sIEB has a "thirty amp" plug--but the generator can not do more than about 22 amps running flat out. (plus a boost of 500 watts for ten seconds).
Regards, Don
dewey02
Why on that Camping World link to the Champion 3500 does it say:
Champion 3500 Watt Inverter Portable Generator
Catalog Item # 88537
This Item is In-Stock and Ready to Ship
Internet SALE
$999.99 SAVE $300.00
Reg $1,299.99
Receive FREE Generator Cover with purchase of Honda Generator. Free cover will be added to your cart automatically.
Are they trying to dissuade you from buying the Champion Generator that they have on sale?
Lantley
nineoaks2004 wrote:
I just purchased the Champion 3500 / 4 KW generator, I tried it out and it ran everything in my Coleman Lantern, plus an air compressor and a large skill saw, just to see, it never even slowed down or stumbled, even with AC and microwave both running. I got it at Lowes on sale and it came with the wheel kit, cost with military discount was 263.00
The OP is referring to the inverter model.
19'Duramax w/hips,12'Open Range,Titan Disc Brake
BD3,RV safepower,22" Blackstone
Ox Bedsaver,RV760 w/BC20,Glow Steps, Enduraplas25,Pedego
BakFlip,RVLock,5500 Onan LP,Prog.50A surge,Hughes autoformer
Porta Bote 8.0 Nissan,Sailun S637
Correct Trax,Splendide
2oldman
I don't think that's what OP is asking about.
nineoaks2004
By the time you learn the rules of life
You're to old to play the game
LIKE2BUILD
Mandalay Parr wrote:
bowl2764 wrote:
Yes my mistake "Champion 3500 watt inverter generator".
Oh, ok. That makes more sense.
Jerry Parr
Champion 3100 on sale for $850.
Sustained output of 2800 watts which is a max of 23 amps at 120 volts.
KJ
'14 Ram 2500|Crew Cab Long Bed|4X4|Cummins
Curt Q20 with Ram 5th Wheel Prep
2000 Crownline 205BR
1997 Ranger Comanche 461VS
'01 Polaris Virage TX PWC
'94 Polaris SLT750 PWC
3 Wonderful Sons (21, 15, & 13)
1 forgiving wife!!!
LIKE2BUILD
2oldman wrote:
LIKE2BUILD wrote:
If the output is divided among all the other 120V receptacles you might find the amperage available to the TT-30R receptacle is less than needed. At 120V, 3200 watts provides 27 amps.
Perhaps OP needs to download the spec sheet or worse, the schematic.
It's a stretch to think they'd put a 30a socket on there and not provide full power to it.
Exactly. If they put a 30amp socket on there, you'd think it would deliver a full 30 amps to it. At bare minimum the max the OP's suggested genset will deliver is 27 amps.
Champion 3500 @ Camping World.
1 forgiving wife!!!
Mandalay_Parr
Jerry Parr
Jerry Parr
Full-time
2005 Mandalay 40B
Cat C7 350, 4 Slides
Blue Ox, Brake Buddy
2004 CR-V Toad
jrparr@att.net
602-321-8141
K7OU - Amateur Radio
Kenwood Radios
ARRL, W5YI, & LARC VE
SKYWARN Weather Spotter
MFL
Nomad II
Nomad II
I think that would be a great generator! Many people were happy with the 3100 older version. The 3500 is fairly new, so not many reviews on this forum yet. I wonder if they might discontinue the 3100, since not a big difference between the two. It seems the 3500 is just more power, that will most likely handle 15K AC, under most conditions.
Might be some good sales coming on the old 3100?
Jerry
2oldman
LIKE2BUILD
Possibly. If all 3200 watts are available to the hot leg of the TT-30R receptacle you most likely can. If the output is divided among all the other 120V receptacles you might find the amperage available to the TT-30R receptacle is less than needed. At 120V, 3200 watts provides 27 amps.
Case in point: I got a great deal on a Generac 3250 a couple years ago. It was listed as 3750W start up, 3250W running. I thought that should be plenty to run the A/C or alternatively the microwave. As it turns out the genny kept overloading and kicked out. What I found was that model being a 120/240 volt model split it's amperage between the two hot legs. So, out of the total 27 amps that were generated, only 13.5 amps was available to each 120 volt circuit. So, under heavy load it couldn't run my A/C.
Granted, the Generac model wasn't RV specific but if I had done a little more research I would have found that discrepancy and looked for a genset that delivered enough amps on the 120V receptacle.
KJ
1 forgiving wife!!!
