โNov-25-2013 05:06 PM
โDec-02-2013 04:34 PM
AlBeGone wrote:
I agree with TomG2. Also, the previous gen 5.3L had enough with 8K lbs.
โDec-02-2013 04:32 PM
TomG2 wrote:navybanker wrote:
TomG2 - I am researching this purchase (2013/2014 2500 HD with 6.0/4.1). The fifth wheel towing capacity is rated at 14,200 or 20,500 gross so this truck should be able to pull the Montana 3400RL as far as I can tell. ...snip..........
I am certain that it will pull the trailer. I am also certain that I would feel underpowered towing anything over 10,000 pounds with a 6.0 regardless of the rear axle ratio. My 2009 had the 4.10, my 2013 is a 3.73. It will get you there and back and my expectation of performance may well be different from others.
โDec-02-2013 09:19 AM
โDec-02-2013 09:05 AM
โDec-02-2013 07:01 AM
โNov-30-2013 05:07 PM
โNov-30-2013 04:19 PM
โNov-30-2013 02:29 PM
โNov-30-2013 08:23 AM
navybanker wrote:
ksss - I am considering a new 6.0 in a 2500 or 3500 SRW. Now have a 04 Duramax 2500 which has been a good truck. My fifth wheel is a 3400RL Montana at 12.500 dry and probably 14,500 loaded. Just needing more advice on pulling heavy with the 6.0 and 4.1. I try to avoid steep/high elevations (such as I 70 west of Denver) since the diesel does better than the "driver" pulling over them. Thanks,
โNov-30-2013 06:26 AM
โNov-30-2013 05:22 AM
Taco wrote:
The 5.3 and 6.0 are both good engines. I wouldn't make my decision on the engine, they both have enough power to get to where you are going. I have a 2012 6.0 and I am satisfied with the power and towing performance. It is on the thirsty side 12 mpg mixed city, 16 mpg highway, 8.5 mpg towing 8k lbs.
I have had both 1/2 and 3/4 ton and the 3/4 ton truck can handle a lot more load/trailer than the 1/2 ton. From the sounds of it you use a truck like a truck and need one that can handle some load.
A 1 ton srw would also be an option to consider, it would be basically the same as the 2500 but cost a few 100 more and able to haul a few 100 lbs more.
APT wrote:
Keep in mind the tow rating for the 6.0L/3.73 is only about 9500 pounds. Going to 4.10 bumps it up by a good amount, about 14k. The 4.10 can be hard to find new and used. As you search, look at the RPO sticker in the glove box for one of the following:
GT4 - 3.73
GT5 - 4.10
You may want to wait to see what the 2015 HD has to offer. You can already order one now for delivery early next year. I expect the gas engine to be significantly more powerful than the 07-14 6.0L.
โNov-28-2013 05:11 AM
โNov-27-2013 04:20 PM
โNov-27-2013 04:12 PM
