After 500 easy miles I hooked her up and hit the mountains. There's a handful of 6 and 7% grades and it was around 100 degrees out. But I have to first mention the empty mileage doing 55 mph this thing got crazy good mileage. 38.9 mpg on a 52 mile trip
That probably won't happen often but it did.
Going up to the Mogollon Rim is a pretty good pull and my trailer was right at 7,400 lbs. I set the cruise at 60 and it sat around 1500-2400 rpms. On the hills I dropped the cruise to 55 and it stayed around 2500-3000 rpms and on the 6-7% hills I dropped the cruise to 50 and it sat around 3400 rpm with plenty left over.
I was really surprised with how well the engine brake worked on the down hills. I pretty much left the cruise on and it would just keep down shifting as it needed to hold the speed and worked with out the cruise on too.
I was surprised how well it pulled the hills but the mileage was my biggest surprise. I got a solid 12 miles to the gallon on the way up and 16.7 mpg on the way back down. With about 10 miles unhooked while I was there. The trip averaged a confirmed 14.5 miles per gallon.
I have done this trip many times with many different trailers and trucks and if I ever got 10 mpg on the whole trip I was doing ok.
In the past I would never risk trying to make it on one tank but this thing was between a 1/4 and 1/2 tank when I got home.
I went ahead and got a new 4way hitch also and I would have to say that this truck really handled my weight well.
If I were towing over 8,000 lbs I would get a 3/4 ton truck but I am really impressed with this truck.
I did try manually shifting but found it a waste of time since going uphill or downhill this thing seemed to find the right gear.
I did take it easy since it is new but VERY happy with the first tow!
2022 Chevy Silverado RST Duramax NHT
1954 Chevy 3100 Carryall 4x4
2008 Salem T23FBL
04 FXDL Harley
