chevy suburban
stevea56
i am planning to purchase a chevy suburban to tow my travel trailer - some come with rear "barn doors" and some with hatch type - any recommendations or preferences on which is better?
23 REPLIES 23
befu
I might be unique here on my experience. I have two - 2004 k2500 8.1L Suburbans currently. Both are even white! The only difference between them is one has the lift gate, the other has the barn doors.
Both will open while hooked up to my trailer. I do have an electric jack that is fairly short on my trailer. Close, but it does clear.
Not sure which one I like the most. It is nice to use the barn doors because you can open only one side. I never have bumped my head on the barn doors (I am tall). It is nice to be able to pop the lift glass on the tailgate version and put stuff in the back. Or open the lift gate and be able to be out of the rain while loading groceries. It is easier to pull the burb into the garage a bit further and still be able to get in the back with the barn doors, the lift gate requires much more room to open it. Visibility with the hatch is better due to no center obstruction. hatch also has a windshield wiper, which is nice. Groceries that have shifted have never fallen out of the back when I only opened the hatch glass. I have had some 2 liters roll out when the barn door is opened up and explode. That was fun, mainly because it was my wife and not me who opened the door.
they both have pros and cons. I guess if I found the burb I wanted, I would not let either option stop me from buying it. Then again, I have proved that by owning both I guess.
Oh, and rust not sure. My 94 had doors, never rusted. My 99 the tailgate bottom rusted out and I had to replace it. 2004 both are rust free, one is not driven on streets in winter as it is left hooked to the camper for mobility.
Good luck
2012 Puma 31dbts TT
2004 Suburban 2500 - 3.73 - 8.1L - 4x4
Helping global warming at 496 cubic inches per revolution!
the_happiestcam
Have had both, and could open either one while hitched. The advantage of the liftgate is if you are loading groceries or something while it is raining, the liftgate acts like an umbrella.
Me ('62), DW ('61), DS ('97), DS ('99), DD ('03)
2003 Yukon XL 2500 8.1L 4.10 axle
2010 Dutchmen 28G-GS
CG's we've been to
campigloo
Get the black one. They look like you're a G-man.
RVcircus
I have barn doors and like them. When I think of Suburbans I think of barn doors...they just go together to me.
2000 KZ Sportsman 2505 (overhauled & upgraded 2014)
2016 Chevy Express 3500 15 passanger van
6 humans, 2 cats, and a dog
Visit our blog at www.ROWLESmade.com
Our trailer re-build thread
PAThwacker
6.0 3.73 4x4 lt3 leather. Dual buckets and sunroof. Oh how I wish it had a big block.
2015 Keystone Springdale Summerland 257rl
Tow vehicle: 2003 GMC K1500 ext lb
Previous: 14 years of 3 popups and a hybrid tt
geotex1
Our 2004 Yukon XL 2500 SLT with 3rd row bench, 2wd, 8.1L, 4.10 geared, 8600 GVW and stickered payload is 2440# and the maximum trailer weight is 12,000# and GCWR is 19,000#. I don't believe GM ever made a more capable full-size SUV than this configuration. It gets 10.3mpg combined driving or towing our ~7200# loaded TT. Doesn't matter and it doesn't sweat the hills either!
PAThwacker
I haul wood, dead deer, tow camper, and jon boat. Occasionally 3 rows for the mother in law.
PAThwacker
K2500 subs were built with towing upgrades to the transmission, axles, suspension, engine, lt tires, ect.
Glamper Denali 1/2 ton AWD have a 6.2 but lack the 2500 upgrades.
The k2500 is currently dead due rear crunch zone/irreplaceable hitch and unable to tow heavy tongue weight.
True_temper
I want one with barn doors they are a lot easier to load and unload heavy loads with a forklift.
krobbe
I recommend a 2001 to 2006 2500 Suburban/YukXL 8.1L to tow. (If you can find one)
After that, 2008 to 2013 2500 6.0L with 4.10 axle.
The 1500 Subs/Yuks don't have much payload. Especially if you're carrying a family.
Me'62, DW'67, DS'04, DD'07
'03 Chevy Suburban 2500LT 4WD Vortec8.1L 4L85-E 3.73 CurtClassV
'09 BulletPremier295BHS 33'4" 7200#Loaded 1100#Tongue Equal-i-zerHitch Tires:Kumho857
Pics
APT
The barn doors went away on by 2004, maybe 2005 on the GM full sized SUVs. So If you want something later, then you have to get the hatch. On the 2007-2014 generation, the rear door has two opening options. Glass only or full rear hatch door. I cannot speak for the 2000-2006 or 2015+ models. My 2011 model can open either method with my TT attached.
It is true that there is one model 2000+ 2500 that has a lower tow rating than the Denali Yukon 6.2L. That is the 2000-2006 6.0L/3.73 axle. The 6.0L/4.10 and 8.1L with either axle have higher tow rating than any half ton SUV. Since you mentioned 6.2L (2007+ model GMC Yukon Denali Only) and are discussing tow ratings, keep in mind that towing a travel trailer at any of these ratings will likely exceed at least one other of all these vehicle's ratings. If you like Denali level of equipment and have a larger family, then payload will be a problem.
Can you narrow down the years in which you are interested?
I'll put a plug in now for the 2008-2013 Suburban 2500 and Yukon XL 2500. They are kind of rare, but every one has the necessary towing equipment standard. It should handle most 8000 pound loaded TTs with at least 2000 pounds of payload and 1000 pound TW limit. The powertrain is rock very reliable and gets decent fuell economy for it's size. We love our 2011!
2017 Subaru Outback 3.6R
fallsrider
I have the liftgate, and the glass will also open separately. I like this configuration a lot. Both will open while hitched, unless I'm turned at a reasonably sharp angle.
opnspaces
Navigator II
Navigator II
My Suburban has the barn doors. I don't like them because there is a big center post that is right in the middle of my rear view.
bcsslc
2014 & 15 suburban is 1500 only. check tow capacity but pretty sure it's under 8300,even less than the new tahoe.
