bkenobi
Mar 24, 2020Explorer
Cleaning NL (fiberglass) shell
I have a 2007 NL that currently lives outside uncovered. I'm hoping to get that resolved this year, but in the mean time I'm curious about proper cleaning others have performed. I wash it less than it should be really, but need some guidance on lichen and streaks. The sides get sprayed when they start looking green but I dont get up top often.
I have a soft brush on a pole and a microfiber covered sponge thingy. I usually use auto soap with "wax" in it and go to it. In areas that are bad, I have stiffer brushes and used dawn this time. Cleaned the sides ok, but the top is fighting back a bit. And what do you recommend for streaks (water drain path down from battery door for example)?
Camper place recommended 303 Aerospace Cleaner but reviews suggest that it leaves silicon. If I was properly wont silicon be a problem?
