Jan-27-2016 08:52 AM
Jan-30-2016 03:13 AM
Jan-29-2016 04:02 PM
Red-Rover wrote:
There was a problem on some 2002 F250's for sure and perhaps the 2001? that dealt with this very symptom. Some came from the factory with insufficient lube (grease) in the splined U joint yoke that extended into the transmition. The drive shaft slides on the spline during acceleration.
Jan-29-2016 10:49 AM
Jan-29-2016 08:38 AM
Jan-29-2016 05:26 AM
Jan-28-2016 07:58 AM
kevden wrote:
The slip yoke on the tail of the transmission is common for this clunk. Might be worth looking into.
Jan-27-2016 04:52 PM
Wes Tausend wrote:
Are you sure you didn't mean oil "filter" instead of oil cooler? I'm not sure, but the leaky canister shape doesn't look like a "cooler".
Wes
Jan-27-2016 04:45 PM
Jan-27-2016 04:40 PM
Jan-27-2016 03:47 PM
Jan-27-2016 02:55 PM
carringb wrote:
That leaky thing is an inline transmission fluid cooler. Required by Ford if you've ever had the transmission apart, but a good thing to have anyways (I run the same one too preventively). A little seeping is noting to worry about, although trimming bit of hose on either end and new clamps should fix it. Most definitely not your source of the clunk.
Did you check your hubs yet? The front axle isn't build as tight as the rear, so if you have the hubs locked in, the slop on the gears and axles can cause clunks when you are in 2WD.
Jan-27-2016 02:01 PM
Jan-27-2016 11:46 AM
