twacke
Feb 15, 2015Explorer
Coleman Pioneer 95 top goes up fine but slowly rides down
Problem: Top cranks up fine with the clicking as I turn the crank. It will slowly ride down once up. Cut custom access door around the crank assembly so now I can inspect. Paw seems to be operating well click with the turns, can not tell if it is worn or spring is weakened. Order new Paw parts and will probably put those in, cheapest solution if it works.
Problem solving: Already tried over cranking, just cranks up to the max then will slowly come down 18 inches or more.
Any other ideas??? Thanks
