opnspaces
Jun 24, 2013Navigator II
Is the unit still on the floor or is it mounted on the trailer? If it's on the trailer, and if the trailer has a converter charger, it might be overloading the circuit. Try flipping off every breaker in the trailer except the AC breaker and then see if it will run. Or try running a heavy duty extension cable up onto the roof and test it that way. That will eliminate any other phantom loads that might be causing a voltage sag.
44,029 PostsLatest Activity: Jan 20, 2025
