Dennis12's avatar
Dennis12
Colorado slides not working
A friend has a 2006 32' Colorado travel trailer that both the living room and the bedroom slides worked fine last year when he stored the trailer. This week he tried to open both slides and neither will do anything. No noise, no action of any type. We checked all fuses and they are fine. Please help.
  • If the battery was/is low, the current draw would have been high enough to blow the 12v fuse when trying to operate the slides. Charge battery, replace fuse, then operate slide(one at a time).
  • pira114 wrote:
    Assuming the battery is good, check all your connections. Especially the ground.
    Yes, this, but check battery state of charge first. It takes a well charged battery to operate the slides.
    Jerry
  • Assuming the battery is good, check all your connections. Especially the ground.
