I'm trying to install a Garmin backup camera on my Lance 845. Want it wired to a rear marker light, so I can use it when driving forward or reverse, with lights on.
Tried to remove the center rear marker light to get access to power for the camera and also to see if there is room for excess cable behind the light. After cutting away the caulking I was able to pry the assembly away from the body partially. Then the lens popped off and I see 2 rivets holding the assembly to the body :M .
I have a lot of cable to store somewhere and was hoping to use the space behind the light assembly to do this. Also was planning on drilling through to the inside of the TC from behind the light assembly. Then I would mount the wireless transmitter inside above the door and connect it to power and the camera via the space behind the marker light.
I need the marker light off to see if my idea will work. If I drill out the center of the rivet, I'm
assuming I could then remove the marker light.
Any thoughts on this?
BTW, I've already confirmed that the wireless transmitter above the door provides a good signal to the GPS screen.
Thanks,
