TeamCyBo's avatar
TeamCyBo
Converting standard overhead light
I would like to convert several standard overhead light to two separate light option. It seems that i have seen this mod on here somewhere but just cant find it. We find that sometimes the 921 dual lights are too harsh and would like to modify the rocker to just turn one side on or then both as an option. Anyone on the forum done this before? If so how and what parts do I need? Thanks.
  • Here is what I need. For one it matches very close to what i have from the factory.
    Click Here...
    The only problem is that these take 1141 bulbs instead of the 921. This is important because I have 10 light fixtures and and have 921 LED replacements ordered and will be here soon. If anyone has a link to a replacement fixture I would greatly appreciate
    It. "Or" if someone knows of a good micro switch that I can add.
    Thanks
  • I bought the complete LED light fixture from Panther RV to replace my old interior bulb fixtures. It is just two wires and you are done.
  • Well guys, I was kinda hoping for a little more info. Maybe someone has done this mod and used x, y and z parts. Does anyone know of a rv rocker switch that can be swapped out! I realize that i can just go out and buy all new lights but where is the fun in that, lol? Maybe someone will come along with more info. Thanks :)
  • Replace the fixture or buy an appropriate switch and install it in the existing fixture.
    If you're not comfortable finding and installing a switch, a new fixture is an easy swap and would likely look more finished/professional.
    Happy Camping!
    John.
  • Easy, just replace the fixture...This one has the option of on/off or 1 only or both sides on.
    LINK
