oyarsa's avatar
oyarsa
Cord Storage and Clearance Light Sealing/Questions
I have a couple projects to do. First, our trailer has a power cord that is pre-connected in a storage bay with a round hatch/access door. One of the screws holding the hatch has stripped and the sealant around the hatch has come loose.
Any suggestions for fixing a stripped fiberglass screw hole? I'm a novice handyman at best. What should I use to reseal the area around the hatch.
I'm also planning to install a backup camera. I'm following a YouTube video that screws the camera bracket into a clearance light fixture. What sealant should I use there? How should I seal the middle bracket hole the cables come out of? Any reasons this is a bad idea?
  • Boomerweps wrote:
    Another option is to removing permanently connected power cable and install a power inlet jack that is sealed entirely. Then add the plug to your existing cable.
    That's what I did Here's how I did it.
    I now store my cord dongles and adapters in the cord storage hatch
  • JB Weld has a material for doing wood repairs. I use it and it worked well. I think it would be perfect for this type of repair.
  • Another option is to removing permanently connected power cable and install a power inlet jack that is sealed entirely. Then add the plug to your existing cable.
  • Wood and glue, epoxy and re-drill, larger screw, insert a piece of electrical wire into the hole and reinstall screw are a few ways I can think of.
  • Fill the hole with wood toothpicks and glue, then drill a hole smaller than the screw. Dicor will seal the seams and bracket.
