Cost of a new EPDM roof?
Photog101
OK, it has been a month since I have had a chance to get any estimates on getting new EPDM roof on my TC. I am in the middle of a restoration on my TC and having a tree limb come through the roof, last month, just hastened a new roof.
Has anyone had a membrane roof renewed on a TC? I am curious as to a price and how long it took. Does anyone know of a good shop ... preferably in Michigan ... that does roofs? I have three appointments set up for later this week and would like to have some idea if they are close.
Mine will take about 19'-21', long, of material. I know that everything has to be stripped off the roof, the moldings and hardware removed, the old rubber removed, the wood inspected and replaced as necessary and possibly insulation. Then the new membrane laid down, glued in place and all the roof fittings replaced.
I know it is labor intensive and the labor will be higher than the materials. I used to work on RVs before I was forced to retire with health and joint problems. We used to ballpark the estimate at about $110.00- $125.00/ running foot plus any extra work that had to be done. We could kick them out, with two men in about 30 hours for each man. AND these were 35-38' motor-homes. I remember four that I worked on and it was not all that bad, inside a shop.
So I know what needs to be done, I just don't know how much the pricing has changed since the 1990's.
Combat Vietnam Veteran Support our troops for serving our great country.
1997 Veri Lite RL1200 on a '02, K3500, CC, DRW, 8.1L, Allison, 4.1 gears, Bridgestone 225/70R19.5 tires.
'12 C2500, EC, 6.6L Duramax
A couple of older 5th wheels housing homeless vets.
16 REPLIES 16
sleepy
Since you have to replace it.... you might think about TPO instead.
The sun doesn't hurt TPO, it is tough... almost impossible to punch a hole in without a firearm.
It will not oxidize (chalk)
No streaks on the sides of your camper from the milky edpm oxide run-off.
It comes in a roll 8' wide and as long as you need. Roll the edges over the roof's slightly... rain runs off. You can cut it with industrial sissors or a good utility knife... for the AC, and other vents.
I originally had an aluminum roof... I have had a TPO roof since 2006. Lance installed it (insurance job)
Good luck
Sleepy
2003 Lance 1161,/slideout/AGM batteries/255W Solar/propane generator/Sat dish/2 Fantastic Fans/AC/winter pkg
AirFoil, Trimetric, LED lights, Platcat vent heat
2003GMC K3500 LT/Crewcab/duramax diesel/allison/dually/4x4/OnStar/front reciever mounted spare
travelnutz
Sent you a PM in reference.
A superb CC LB 4X4, GM HD Diesel, airbags, Rancho's, lots more
Lance Legend TC 11' 4", loaded including 3400 PP generator and my deluxe 2' X 7' rear porch
29 ft Carriage Carri-lite 5'er - a specially built gem
A like new '07 Sunline Solaris 26' TT
