bcarroll's avatar
bcarroll
Couple of concerns I noticed over the weekend
I took my 1 yr old Dutchment 275BHS camping over the weekend, first time without any hookups, and a couple of issued came up...
First of all my battery did not make it thru the weekend. I had plugged in my trailer about a week before we left so it should have been at a full charge.
I have electronic tongue and stabilizer jacks, and after leveling, stablizing and unhooking, I checked the battery charge and it was down to 2/3 charge. First night we did not use the lights, only the water pump. 2nd night we used lights too, maybe about an hour of one or two light fixtures, and the next day the battery showed less than 1/3 charge. I took it to an auto store to get it checked and they said they would have to charge it for an hour to even test it as it showed 0 volts. They charged it, and told me it is a good battery, and that it is now fully charged(after an hour...?). Took it back, re-connected it, and in the morning the battery showed 1/3 charge.
Don't batteries last longer than a night or two?
Second thing...my water pump would run for 5-10 mins after all faucets were turned off, I got to just turning it off when done. When I turned it on again it would start running right away. The water would spit and sputter out of the faucets.
Third thing ...my hot water would come out of the cold tap. This did not happen before when hooked up to water.
What might be going on?
