Jul-23-2014 10:06 AM
Jul-23-2014 02:00 PM
spoon059 wrote:
I went to the hobby store and bought some cheapo foam a couple inches thick. Cut it about an inch wider and longer than I needed and stuffed it in the vent opening. Because its a little too big, it holds itself up. Because its foam, it helps insulate. It cuts most of the light, but lets some light through. If you want to make it dark, wrap it in dark fabric.
Jul-23-2014 01:28 PM
Jul-23-2014 01:25 PM
Jul-23-2014 12:47 PM
Jul-23-2014 12:43 PM
Jul-23-2014 10:55 AM
Jul-23-2014 10:24 AM
Mark Heisler wrote:
our skylights have roller blinds
the blinds looks the same as our windows but smaller with magnets on the end to hold it up
Jul-23-2014 10:20 AM
ECones wrote:
Our travel trailer has two skylights and two roof vents which the AC has a problem overcoming in the bright sun when the outside temps are 90+. We found some vent covers which should help with them, but the skylights are quite a bit longer, and we've found nothing to help there.
I'm just looking for ideas and wonder what some of you folks may have done.
Right now, the plan is to use about an inch of foam exterior sheathing cut larger than the skylight and self-sticking Velcro as temporary attachments.
Suggestions welcomed.
