Teamfour
Aug 30, 2014Explorer
Damaged my TT - Need Advice on Repair - UPDATE
On our way to Lake Placid last Saturday, I hooked a post pulling away from a gas pump. I pulled the rear outer wall away from the aluminum frame. There is no damage to any inside structure, nor is there any cracks or structural damage to the outer wall. I can just about push the corner back in to contact the aluminum frame, the location of which is indicated by my finger. My insurance deductible is $250.
Would you have the damaged repaired by the dealer and payed via insurance? Or would you attempt to push the corner back in and use construction adhesive to reattach the wall to the frame. Would it be OK to drill pilot holes in the bonded fiberglass and screw into the frame? Obviously the lower side skirt needs to be replaced.
Our concern is that our local dealer would not know how to repair this or a trip to the factory would be needed.
