Terryallan wrote:
brulaz wrote:
One more thing, if you're going down a hill with lots of sharp 20mph turns, that can be a lot harder on your brakes than a steeper, but straighter and faster descent like on the Interstates.
And the drum brakes will fade faster on your trailer than the disk brakes on your truck. The trailer brakes will need constant re-adjustment via your controller as they heat up. On the western descent with all the hair-pin turns down the pass in Great Smoky Mountains N.P., I kept increasing the voltage to my trailer brakes as they heated up so the trailer would keep doing its part. I also started manually operating them to give the truck brakes a break. That was all in 2nd gear. All the brakes were stinking hot by the time we got down. Probably should have pulled over to let them cool.
Appears that 2nd gear was too high for your needs. You should have used 1st. You would have saved your brakes. OR. you have a diesel with no add on engine braking.
Another gear between first and second would have been perfect. But in first alone, it would not go over 15-20 mph without screaming (not sure of the rpms, definitely high).
The speed limit is 35mph down the mountain, but the hairpins are all 20 mph (and there's many, a dozen?). Never put my foot on the throttle, but in second gear it would accelerate to 40 mph between the 20 mph hairpins, so I would have to brake.
Yes, engine braking is not a strong point for the 3.5L Ecoboost. It could get me up that hill real quick. In fact it was a blast, like a 15,000# sport car. But coming down is another story. And it's the only the west slope of the Newfound Gap highway that's a problem. East slope is easy, not so many hair-pin turns.
But now that I know what's what, will be more prepared next time. In particular, will be looking for a place to pull over and cool down about half way down the mountain. There's a lot of nice hiking trails in the Smokies, that's why we go there.
Also might get slotted discs and more aggressive brake pads, but the originals still have a lot left so that won't be for a long time.
