beachlovingmom's avatar
Jun 19, 2013
Detailing
We are new to the forum. Earlier this week, I asked about replacing the vinyl stripes. THANKS for all the suggestions! One person mentioned "detailing" prior to replacing the stripes and I can see how 2 sides of the fiberglass trailer could really, really use that. But, where do a I start? Is there a link or a web site with instructions? It is a 2005 Dutchman Adirondack if that helps. Is it more than washing and waxing with car wax? Does it HAVE to go the dealer or can we do it ourselves? If so, what do we use? Husband wonders if rubber roof needs additional care?
Thanks for all your help
  • Chances are, if the graphics are bad, then the gelcoat is oxidized, which means it will need to be buffed out and then polished to a shine.
    First thing to do is remove the graphics. If you're going to replace the vinyl with the same design, then you won't have to worry about any shadowing left behind and here's why... when vinyl gets weathered from the sun, it shrinks first before it becomes an eye soar. With that in mind, you first need to strip the graphics using a heat gun and some plastic razor blades. It is actually better to strip the graphics in the direct sun as the heat from the sun helps soften the vinyl. Re-applying the graphics is done by simply lining the new graphics up to the shadow left behind by the old graphics.
    When you receive the new graphics, they should be sandwiched between a top layer of transfer tape (better recognized as masking tape) and a under layer of paper that is peeled back revealing the sticky side. There are several youtube videos that demonstrate how to apply graphics, it's simpler that you think.
    Once the graphics are off you can wash the RV using a dawn dish detergent and LA Awesome mix. This will strip most of the oxidation and left over wax off the RV. Do not use this mixture on the roof - this is for the sides only. Chances are, you have either a EPDM rubber roof(ethylene propylene diene Monomer (M-class) rubber) or a TPO Rubber (Thermoplastic Polyolefin) roof. It is advised not to use anything that contains petroleum distillates and citric ingredients when washing a rubber roof. These chemicals will damage your roof membrane and shorten its life.
    Once this is done tour RV is ready for detailing. To protect your new graphics from future weathering, apply some 303 Aerospace over the graphics every 3 to 6 months and they should last a lot longer. Good Luck
  • I don't think I would wax the trailer before putting on the graphics. I would just give it a good scrubbing with an RV or car wash soap solution.
    I'm not sure what suggestions you got for putting on the graphics but you can use a spray bottle filled with soapy water. Spray the graphics area with the soapy water and begin installing the graphics. Use a squeegy to remove the air. The soapy water will allow you to slide the graphics and when it dries the graphics are permanent.
