Dexter Torflex Axle
4aSong
Looking for recommendations on a good repair facility in Nevada or Arizona. Prefer Las Vegas, Flagstaff or Phoenix area that has the proper equipment and experience for aligning the Dexter Torflex axle.
M & N
Tundra TRD V8 4x4 w/Leer Shell
EU2000i * Prodigy * McKesh * Trek * Renogy * ENU
4 REPLIES 4
brulaz
I was getting excessive wear on the outer edge of the curbside tire on my single axle old trailer. Trailmanor just replaced it under warranty and sent it back to Dexter. Since then I rotated the tires, so wouldn't know if that fixed it or not.
2014 ORV Timber Ridge 240RKS,8500#,1250# tongue,44K miles
690W Rooftop + 340W Portable Solar,4 GC2s,215Ah@24V
2016 Ram 2500 4x4 RgCab CTD,2507# payload,10.8 mpgUS tow
Ivylog
Considering you can buy a new axle for less than $400, not sure I'd have someone try and bend it if it's in that bad a shape.
Upgraded with a 08 HR Navigator 45โ€™...
VintageRacer
The axle itself can't be "adjusted" in the sense of shims or bolts that can be moved to change alignment. If it is installed at an angle, you would have toe out on one side and toe in on the other side so you would have to un-bolt the whole axle and move it on the chassis frame to correct. If a single wheel has toe in or out, you probably have a bent arm and the axle would need to be replaced. If you are looking at a pretty small adjustment shops (mostly truck spring shops with big equipment) have been known to bend the axle tube in the middle to change camber or toe, but that's not really an adjustment, it's a bit more than that. You might have someone suggest heating and bending the suspension arm but that usually would melt the rubber torsion springs inside the tube and isn't recommended.
Brian
2005 F250 Supercab, Powerstroke, 5 speed automatic, 3.73 gears.
20 ft race car hauler, Lola T440 Formula Ford, NTM MK4 Sports Racer
1980 MCI MC-5C highway coach conversion
2004 Travelhawk 8' Truck Camper
Francesca_Knowl
If the Torflex is bolted on there may be some small adjustments that can be made, but I'm pretty sure that other than that a Dexter Torflex can't be "aligned" in the traditional sense.
" Not every mind that wanders is lost. " With apologies to J.R.R. Tolkien
