lgbrotz
Jun 06, 2014Explorer
Diesel transfer from spare tank
I have a small (15 gal ) spare diesel tank in my tool box on a F-250. It was on the truck when I bought it. It is rigged with a transfer pump that plugs into a 4way light hook-up for power and transfers to the main tank with a hose. The problem is that I have to stop to make the transfer. I want to wire the pump to a switch in the cab and pipe the hose into the filler tube of the main tank so the transfer can be made while driving if needed. Some truck owners have stated that this wlll pressurize the main tank and cause problems. Any thoughts or ideas as to what I may run into doing this setup??
