rmoparman's avatar
rmoparman
Dillions
Was looking at inventory at Dillions. They have only 4 dullys. Rest are SRW. The prices are to die for.
Dodge 31 from Henderson NC has best inventory but price are much higher. Dillons cant be beat.
Need dually because you can never have enough truck
  • Its Dennis Dillon and he has a few stores in the Boise Id area. Also sell rv's and has moved into the so Ca market as well.
  • the OP spells it Dillions and then Dillons. which is it and where are they located.
  • Need dually because you can never have enough truck
    If you are moparman you are probably looking at a new Ram. Dennis Dillion has four, you want one, what are you waiting for???
  • If a dually is barely enough truck, maybe you should look t a tandem rear truck.....if one can not have too much truck any how!
    Ryder and Penske have MDT's. BUT, issue with many of these, they are speced HP wise from a enough power to move the truck at gvw only. Rarely do they have powerplants for true towing power. Chassis wise they are fine. But usually with a 250-300 hp motor, possibly in the 200-225 relm too vs wanting a 350-400hp motor for true towing at the gcw that the chassis is capable of running at.
    marty
  • Might take look at Dave Smith up in Kellog, Idaho. They are supposed to be pretty good as well.
  • Around here dealers will match, or at least come close, to local competitors prices. Try it. End of December is a great time for bargaining as dealers are trying to make end of year numbers.
About Travel Trailer Group
44,025 PostsLatest Activity: Feb 06, 2025
