- dodge_guyExplorer II
FishOnOne wrote:
dodge guy wrote:
Went to class last year on it. The turbo isn't cast into the head. They are using a cast in manifold which then the turbo bolts to the head or both turbos. We’ve only seen 2 come in off the transport so far. Not a lot yet. So we will see.
The hurricane engine you were trained on was most likely a production version as this new head is not in production yet.
Yes, that sounds like a new design. Probably be awhile before it sees production. - Grit_dogNavigatorGreat….so now I gotta go buy a Hellcat before the price of them goes even further thru the roof…..I was having a good day until I read that article…lol.
F the pandemic and the chump that rode its coat tails into the White House!! :B - BB_TXNomadI wouldn’t buy the 1st or 2nd year models.
The hurricane engine you were trained on was most likely a production version as this new head is not in production yet.- Bigfoot_affairNomad II
You must have fallen asleep. The patent drawings show a cylinder head with the housing as one. Good luck with that!
Hurricane head - dodge_guyExplorer IIWent to class last year on it. The turbo isn't cast into the head. They are using a cast in manifold which then the turbo bolts to the head or both turbos. We’ve only seen 2 come in off the transport so far. Not a lot yet. So we will see.
About Travel Trailer Group
44,028 PostsLatest Activity: Dec 10, 2013
