Dodge Ram 3500 SRW Max Payload????
bowler1
Hi,
I am looking to buy a one ton diesel truck and need a high payload for the trailer I am looking to get. I am pushing the limits of a SRW but really don't want a dually so I want the highest payload I can find with the features I want/need.
The truck will be a crew cab and probably a long bed and I am looking at the Laramie package. I realize that all of these options reduce the payload.
For any of you who have this truck can you tell me what your DOOR STICKER says for max payload (along with whether your truck is a crew cab, etc. The F-350s I have looked at that are similarly equipped are around 3200. I am hoping I can get a bit higher than that.
thanks
Matt
38 REPLIES 38
Cummins12V98
"I have 14,560# worth of tire capacity and 12,300 gvwr. Still a little wiggle room. "
Showoff. :B
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
Grit_dog
Navigator
Navigator
CampingN.C. wrote:
transamz9 wrote:
CampingN.C. wrote:
So if someone were to load a 3500 SRW to max payload it sure wouldn't leave much wiggle room on the tire capacity would it ?
Not really what I was referring to. If one were to load full payload they would be around 7000lb on the rear axle. With the average 18" 10 ply being 3640 per tire that's awful close for me.
I only bring it up because I have approx 800lbs to go before I'm at tire cap and I thought that was close until I started looking close at 3500 SRW specs.
I hear what you're saying, but it's not really a thing. I've been driving pickups day in day out (not currently unless you count the dodge and camper) at or over some capacity for hundreds of thousands of miles. Usually shoe 1/2 tons with E load tires after burning off the factory donuts though because I'm rough on tires sometimes.
I can count on a couple fingers how many flats I've had over the years that weren't from a nail or screw or some other foreign object punched through a tire on a construction site.
Think about the liability tire mfgs would be exposed to if tires popped under the dynamic loading of simply a rated capacity load.......huge.
They'll hold up fine to the rated load, at least. Won't last as long as tires that are rated heavier, but they won't pop.
Now yes, overkill tires provide a greater factor of safety and it depends on your intended use (Rock crawling or pounding pavement?) how likely you are to need it.
CampingN_C_
2018 Ram 3500 DRW CCLB Aisin 4.10 4x4
2018 Jayco Talon 413T
B&W Companion
transamz9
2016 Ram 3500 Mega Cab Limited/2013 Ram 3500 SRW Cummins(sold)/2005 RAM 2500 Cummins/2011 Sandpiper 345 RET (sold) 2015 Sanibel 3601/2008 Nitro Z9 Mercury 250 PRO XS the best motor made.
JIMNLIN
depends on which payload is being used.
CampingN_C_
B&W Companion
Campteacher
Hi there,
As per the door sticker, my 2017 Ram 3500 Cummins SLT 4x4 has 3872 lbs payload, and 11 700 GVWR.
Kevin
transamz9
I just looked and it is 3,719#
transamz9
If I remember when I get home I will get the number off my truck when I get home. My truck is a Mega Cab but it will be real close to the same weight as a long bed crew cab. If my memory serves me right my payload from the factory is 3,7XX. The Long bed diesel 3500 SRW and Mega cab both have the highest GVWR @ 12,300#. My truck weighs right at 8,500# and mine is a loaded to the max Limited.
Me_Again
Our 2015 CC SB SRW 4x4 Aisin Laramie has yellow sticker 3664 carry capacity. Chris
troubledwaters
Grit dog wrote:
Cummins12V98 wrote:
troubledwaters wrote:
Get a gasser and you'll get 800 more lbs.
This is where people get in trouble looking to tow a 5er!!!
The extra weight is on the front axle with a Diesel. You carry the 5er on the rear axle.
It's called what can the rear axle carry, NOT what is the trucks capacity or what can it tow. That's the real world.
Please don’t confuse logic and fact with rvnet drivel! Lol.
To the OP, sorry don’t have a pic of my door sticker, Never looked at it....
SRW 1 ton = about 4000lbs payload capacity in any of the newer trucks.
Reading Comprehension 101 - The OP said "Payload" and even mentioned "door sticker says for max payload". I assume he already knows how to ignore the payload rating if that is what he chooses to do.
Grit_dog
Navigator
Navigator
Cummins12V98
"It's already a crew cab and a long bed so you can't park it up close to the store, or navigate most drive-thru lanes,"
NOT true at all. It will fit just as well as any SRW SB out there, also many go thru the drive thru lanes with Dually trucks so a SRW will be a breeze.
I park close with my Dually when I have a curb available. Without my hips the truck would have fit just fine.
Vanished
3957 lbs here, tradesman 4x4 crew short bed Cummins 68RFE
2019 Ford F350 4x4 diesel DRW
2021 Grand Design Momentum 28G
Cummins12V98
"The 6.4 gasser has a 80 lb in the bed payload advantage."
Thanks for that!!!
