LMMNOCATS_EFI's avatar
Nov 18, 2017
Does your truck lean to one side?
Hello all again so i'm back with a small issue ... other day was sting in front of my truck and realized the front end one side sat higher then the other. The truck 08 LNGBD LMM HD has had 2" keys to make it sit level and allow me to stuff 325 60 20s under it and it was always level but having enough of the rough ride I broke down and spent a grand on the spindle CST makes to then put the stock keys back and the new spindle.Everything was fine for about the first month then I noticed the lean .... spindle added was a 4" and a 1" block hoping that would level it....but any how can this be a bad shock or worn key or bar ? Weird thing is the side thats lower (driver) torsion key bolt is cranked 7-8 times were as the (pass)side thats sitting higher torsion bolt is backed out far as possible were the bump stop is resting were it should be on the A arm
I cant figure out why the side cranked can or why it would be lower any one know somtthin "shout out to the devil"
Thanks fellas
